Car hesitates at high rpm's
Old Nov 30, 2003 | 03:12 PM
86WS6_T/A's Avatar
Car: 2003 Mach 1
Ok, started having a problem with the motor in my T/A.
Timing is dead on, plugs and wires are a few weeks old.
Car runs smooth at idle, drives smooth unless you hammer on it.
If you get on the throttle, it will accelerate up until about 3000-3500 rpms, then it hesitates and goes no where.
What should I check first? Everything in the driveline excluding the rear end is less than a month old.
specialized
Jun 18, 2022 09:26 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Linson
Aug 21, 2015 02:12 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
