Sportsman-II Rocker / Stud q.s
Old Nov 27, 2003 | 05:59 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I've searched.
Anyone whos running these.. Do you know what brand stud they use? Arp? I've tried to no avail contacting world.
Also, what roller rockers (1.5) have you used? I know tpi_roc had issues with "crane Blazer". Though after hours searching the net he seems to be the only one.?
-- Joe
Old Nov 28, 2003 | 01:17 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
The Torquer S/R's I had looked like the ARP studs. Not positive though. Why do you need to know? I have used Harland Sharp roller rockers in the past few engines I built. A lot of guys here swear by the Comp Magnum stainless ones.
Old Nov 28, 2003 | 03:17 PM
ede's Avatar
ede
the make of the stud wouldn't really matter the threads would all be the same. i like comp stainless rockers.
Old Nov 28, 2003 | 11:41 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I wanted to know what kinda studs they used to base wether or not I should replace them with ARP. If they're allready ARP, then replacing them would be silly.. I've heard of people breaking studs..
I guess most of the 1.5 roller rockers would fit under factory parimeter valve covers huh??
I need the baffles. On my car at 6k it sprays oil everywhere out of an unbaffled cover (and sucks it up the pvc, etc)
-- Joe
Old Nov 29, 2003 | 11:40 AM
Ricktpi's Avatar
I had to go to the tall baffled cover to solve the oil in the PCV problem. Short baffled ones would not clear the rockers.
Old Nov 29, 2003 | 04:19 PM
Damon's Avatar
I never had a problem bolting stock baffled valve convers to the Sportsman IIs I have used. I was using stock-diameter 1.25" valve springs.
No idea the make of rocker studs. I doubt they're ARP, though. But I never broke one regardless.
Old Nov 29, 2003 | 05:43 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Damon,
I'm refering to clearance issues with roller rockers, not stamped or roller tip.
I cannot cut my baffles out.
-- Joe
Old Nov 30, 2003 | 03:27 PM
86WS6_T/A's Avatar
Car: 2003 Mach 1
I've got sportsman II's with Comp 1.52 Pro Magnums. I already had a tall valve cover but from the looks of it, between the thickness of the rocker and the polylock sticking up, a tall valve cover would be needed anyway.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
New2Chevy
Sep 28, 2015 12:35 AM
Billyadams
Sep 22, 2015 08:25 AM
355tpipickup
Sep 13, 2015 11:35 PM
