Roller rocker question
Old Dec 1, 2003 | 02:20 PM
IROCaholic's Avatar
Car: 89 Camaro RS
Engine: 350 carbed now
Transmission: World Class T5
Axle/Gears: Peg Leg w/ 3.73's
I ordered a set of proform 1.5 self aligning roller rockers this week for my new engine, and I had a question, it says they are made for 3/8 studs, does that mean 3/8 size pushrods or no, if so what size are the stock pushrods in a 70's 010 casting 350 and can I use them with these roller rockers, if not which pushrods do you reccomend. Thanks
Old Dec 1, 2003 | 02:22 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Studs have nothing to do with push rods.
Push rod size does not vary according to block casting. Stock SBC ones are all 5/16" in all block castings.
Stock studs are 3/8".
They should fit fine, except for your valve covers. You shouldn't have to do anything with the push rods.
Old Dec 1, 2003 | 02:23 PM
Blackroc86's Avatar
Car: 1986 Iroc
Engine: 454 Demon 850DP
Transmission: TH350, 3500 stall
They are talking about the stud the rocker sits on not the pushrods. SBC heads have either 3/8 or 7/16 studs. If you heads are nothing exotic you should have the 3/8 studs and the roller rockers you bought will work.
Old Dec 1, 2003 | 10:10 PM
IROCaholic's Avatar
Car: 89 Camaro RS
Alright thanks guys, I hate to ask these simple questions ,but I want to make sure I am not missing anything. Thanks again.
Old Dec 1, 2003 | 11:35 PM
Stingraye's Avatar
Car: 1986 Trans Am
Engine: 350 W/Plenty of Mods
Be careful with those proform roller rockers! I've heard some BAD stories about them, most coming from Jeg's guys on the phone! So if the engine starts acting bad or something is wrong, quit running the engine and pull some valve covers!
Old Dec 1, 2003 | 11:49 PM
IROCaholic's Avatar
Car: 89 Camaro RS
What exactly have you heard, just so I know what to look for.I am going to have a heart attack with this damn engine man. Hopefully they work good for me.
Old Dec 1, 2003 | 11:54 PM
Stingraye's Avatar
Car: 1986 Trans Am
From people around, that they are brittle and the 1.5 ratio is not accurate (one may be a 1.45 ratio, the next one down is a 1.54 ratio...etc), and from a jeg's tech guy, that they've had some come back that were snapped in half and what have you. Just be careful, and if something all the sudden goes drastically wrong when u'r racin that import, first thing i'd check is the proforms. From my past experience I have never had anything work "right the first time" with proform. They're stuff has always seemed sub-par, and I've always found myself doing some kind of fabricating just to get the crap to work. Not saying that's the way it is for all their stuff, and I do hope they work great for you, but that's why I spent the extra to get the crane gold race roller rockers, and I havn't used proform anything for a while now. Good luck bro.
Old Dec 2, 2003 | 12:06 AM
IROCaholic's Avatar
Car: 89 Camaro RS
Alright man, thanks for the heads up, I really wanted to get the crane gold race rockers but I am on an extremely tight budget, I hope that nothing goes wrong but if something does I will probably switch to them Ive heard nothing but good things about them. Thanks again.
Mickeyruder
Sep 2, 2015 02:45 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
LT1Formula
Aug 20, 2015 09:36 PM
Dialed_In
Aug 20, 2015 01:45 PM
IrocZ'85
Aug 17, 2015 06:24 PM
