Stock stall?
Old Jan 1, 2001 | 12:13 PM
new87's Avatar
Car: 87Z
Engine: ?
Transmission: A4
Stock stall?
What is the stock stall an 87 Z28 LB9? Becuase I'm looking at the protorque converter, and the stalls avalible are 1800-2100 or 2200- 2800. It says that the stall is relitive the input troque. So I would like to nknow the stock stall first.
87 Z28 305 TPI, Auto, 2.73, Gutted air boxes, K & N fillters, SLP Airfoil, Dyno Max 3" cat back, Accel 8.8 mm spirals, Accel cap and rotor, Accel coil, rapid fires, and 160 Stat.
Best 15.414 @ 87.47.
Old Jan 1, 2001 | 01:27 PM
ede's Avatar
ede
stall speed is relative to weight of car, Hp and torque. you could go out and power brake the car and watch at what rpm it moves ,that basically is your stall speed. i'd guess it'll be around 1600 to 1800 rpm.
ICON Motorsports
1st & 3rd
Old Jan 1, 2001 | 02:51 PM
Vader's Avatar
New,
I've got the DBCF code converter on my '86. The factory stall speed (K-factor, as GM puts it) is 2,025 RPM. I think I got it due to the 2.77 BW axle. If you remove the inspection cover from the transmission/flywheel area, you might be able to read the four-letter code on the line RPO tag (if it's still there) and determine what stall speed converter you have.
Later,
Vader
"No matter how hard you try you can't stop us now"
Adobe Acrobat Reader 4.0
Old Jan 1, 2001 | 04:52 PM
branz28's Avatar
Car: 1989 IROC-Z
Engine: 383
Transmission: Pro-Built 700R4 2400 ACT Stall
Axle/Gears: 2.77 Borg Warner 9-Bolt
I have the same setup as vader, basically...just got my 2K conv. What can i say, it's a pleasure to drive... If i'm correct though, mine was around 1800, I forget what the tranny guy told me...heh, i was just happy to get my car back
89 IROC-Z 350 TPI
-Flowmaster Catback
-Performance Resource Chip
-700R4 (Rebuilt) Too much done to actually list
-K&N Airfilters
-Ported Plenum
-2.77 Gears (not much to brag about but eh, its there)
-MSD 8.5 mm plug wires
-Problems every other day with the car (probably not a mod, but to me it sure makes a difference)
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
jklein337
Sep 19, 2018 06:23 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
Bryan F
Aug 18, 2015 02:28 PM
TreDeClaw
Aug 14, 2015 06:58 PM
