High idle after removing throttle body
Old Jan 1, 2001 | 03:05 PM
irocbsa's Avatar
I took off the TB yesterday to replace the t-stat and when I put it back on and cranked the car it would idle at 15-1600 rpm in park and about 1000 in drive. I checked all the linkage and it looks fine. I'm pretty sure that the blades are closing all the way. Whats goin on here?
bsa
"If they do not run, Then they will die." - Stonewall Jackson
'87 IROC, 355 TPI,700R4, Trick Flow Heads, Comp Cam, Comp 1.6 Rockers, Lucas 23# injectors, Edelbrock headers, Flowmaster 3'' exhaust, gutted cat, Mallory coil, Mallory HyFire IV ignition box, Mallory Sidewinder 8mm wires, Autolite platinum plugs, K&N filters, Transgo Performance Shift Kit, Corvette Servo, 2,000 Torque Converter
Old Jan 1, 2001 | 03:15 PM
Vader's Avatar
IROC,
If this is happening when the engine is cold, it can be normal. If the idle is that high on a warm engine, I'm guessing you have a vacuum leak or the IAC is sticking open.
Double check the gasket positioning, IAC connector, TPS connector, and vacuum line under the TB (to the EGR solenoid/EVAP canister).
Remove the TV cable if you have an automatic, and remove the cruise cable if equipped. Either one of these could be holdng the throttle open a bit.
Later,
Vader
"No matter how hard you try you can't stop us now"
Adobe Acrobat Reader 4.0
Old Jan 1, 2001 | 09:26 PM
SeanSullivan's Avatar
Had that same problem a few yrs ago, when I put a spacer on the tbi unit. I tore the gasket, once I replaced it no more high idle. it's simple, and cheap to check.
specialized
Jun 18, 2022 09:26 AM
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
lakeffect2
Aug 23, 2015 08:44 AM
ZZ42Fast
Aug 10, 2015 08:20 PM
