Performer Intake
Old Dec 4, 2003 | 10:09 AM
Joshua's Avatar
Performer Intake
I have a 350 with Vortec heads, XE274 cam retarded 4 deg, Rhoads lifters, Hooker SuperComp headers, and a Performer intake.
Now at 5000 RPM WOT Vacuum goes to 1 in. and by 6000 it's at 2. I thought it was the carb so I switched from a Q-Jet 750 to a Q-Jet 800. Same thing. Switched to a Holley 650 DP and the same thing.
I know the performer is designed for idle-5500 but could it cause such a problem?
Old Dec 4, 2003 | 10:17 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yes.
That's why they say it's "designed for" 0-5500 RPM. It's all done once the RPMs get up to that point.
Basically you have a cam/heads/exhaust vs. intake mismatch to the extreme.
Old Dec 4, 2003 | 10:46 AM
Joshua's Avatar
Would adding a 1/2 inch open spacer help the problem? What if I cut down the divider 3/4 of an inch? Or is my only solution to go with the Performer RPM?
Old Dec 4, 2003 | 11:14 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Look at the port cross-section. I think you'll realize right away that dinking around with the stuff at the base of the carb won't change the basic situation very much.
The RPM would actually be an excellent match for the rest of your combo.
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
the performer is almost as bad as your stock intake was.
you might as well get the Vic Jr for vortecs... heh
Old Dec 4, 2003 | 03:39 PM
Joshua's Avatar
Thanks for the help. My main concern is that I have a Q-Jet and a Holley Q-Jet replacement and those don't work on a Performer RPM. I also have a 700 DP and a Holley VS 750 but I'm afraid gas mileage would take a significant dip. I'm going to mess with the Performer a lil more and see what I can get out of it.
Old Dec 4, 2003 | 03:45 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
http://store.summitracing.com/partde...art=EDL%2D7104
Old Dec 4, 2003 | 03:46 PM
Joshua's Avatar
It's not for Vortec heads though.
Old Dec 4, 2003 | 03:51 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
EDIT: nm
Old Dec 4, 2003 | 03:53 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Oh yeah... duh...
92projectcamaro
Jan 18, 2016 08:00 AM
z28guy134
Sep 1, 2015 11:50 PM
DJanes97
Sep 1, 2015 02:55 PM
86IROC112
Aug 17, 2015 02:00 PM
