Car stalls when turning hard
Old Dec 6, 2003 | 04:20 PM
Daemorok's Avatar
Under pretty specific conditions my car will stall when i turn left or right (90degree turns usually).
I have been able to reproduce the stall 3 or 4 times after it happened the first time.
If i am braking and i turn before the car "finishes" slowing down the car will stall mid turn. If i shift to neutral it and turn the key it starts right back up.
If i turn smoothly, it doesnt stall.
Since its an instant stall, and it starts right back up, i thought maybe I had a wire shorting somewhere. I figured if it was fuel related I would get some sort of stutter before the stall, and it dont get that, the car just cuts out.
Ive been trying to troubleshoot this for awhile now, and I cant seem to find any bare wires, or wires that look like they could be shorting somewhere.
anyone have any ideas at all? I am totally lost
Old Dec 6, 2003 | 07:05 PM
357mag's Avatar
Car: 94 C1500
Transmission: NV-4500
Axle/Gears: 3:42 10 bolt 8.5"
Sounds like ypu need to raise the float level in the carb. Your fuel must be sloshing around the bowl whilst you are making a hard turn, causing your engine to run out of fuel for an instant.
Tim sends
Old Dec 6, 2003 | 11:21 PM
GTA88's Avatar
If you have a carb in that 84, that could be the problem. Float bowl. I had the same problem in a carbed car once : stalling on turns (left or right, don't remember). Replacing the carb solved the problem.
Old Dec 7, 2003 | 10:32 AM
Daemorok's Avatar
I thought i was carb at first but a friend of mine said he had a similar problem with a 78 trans am. It ended up being wires that were swinging around and touching the headers.
So this gives me an excuse to get a new carb
Im so sick of my 750 edelbrock anyway.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
