Heater Hoses!
Old Jan 1, 2001 | 02:27 PM
Blue92's Avatar
Heater Hoses!
Does anyone have a good way of getting the heater hoses off the heater core. Mine are stuck and I can't pull them off for anything!
Old Jan 1, 2001 | 02:30 PM
ede's Avatar
ede
i have a tool for hoses, looks sort of like a screwdriver with a bend in it. you hook it under the hose and work it around to break the seal.
ICON Motorsports
1st & 3rd
Old Jan 1, 2001 | 03:04 PM
Vader's Avatar
Snip, snip...
Later,
Vader
"No matter how hard you try you can't stop us now"
Adobe Acrobat Reader 4.0
Old Jan 1, 2001 | 03:24 PM
ede's Avatar
ede
not sure vader is right this time, my way you can reuse the hose. i think if i were removing a hose i'd replace it anyway so maybe vader is right after all.
ICON Motorsports
1st & 3rd
Old Jan 1, 2001 | 04:14 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Razor blade or utility knife, lengthwise along the hose where it's over the nipple; 2 seconds later you're done.
Old Jan 1, 2001 | 06:32 PM
billyde's Avatar
I just received a dremel for Christmas,i'm sure it will come in handy.
Old Jan 1, 2001 | 11:41 PM
I ROCK's Avatar
Car: 89 IROC-Z
Engine: LB9
Transmission: 700-R4
Dremels rock. Do yourself a huge favor and buy a tungsten carbide cutting bit or two. They'll go through anything much faster than the cutoff wheel.
89 Iroc-Z LB9 305 TPI auto 2.73 posi:
3" Dynomax "cat" back,K&N filters, TB bypass, 3" pipe in place of cat, cleaned and flow-matched injectors, 180' thermo, mild ignition mods, synthetic oil, kicker sound system, soon to attempt engine swap...
Old Jan 2, 2001 | 01:31 AM
Bort62's Avatar
Mine Did the Same Jazz Blue, I latched onto them with Vice grips and Gave Em the old Heave ho ( and im a pretty strong guy, I work in a lumber yard... ) and the Damn Thing didnt even Flinch.
So I worked around em.
When I do have to remove em, Ill Follow In Vaders Footsteps.
There are Pruning shears in the Bottom Drawer of My Tool Chest For a reason !
Thats the "BFH, Sawzall, Crowbar, and Other highly refined Tools" Drawer
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver
Livin' the Stereotype
Old Jan 2, 2001 | 01:11 PM
Pat Hall's Avatar
RB's suggestion works every time. One thing you can try first before cutting them though. If you can get a good grip on them with your hands or a pair of channel locks, twist the hose on the fitting. This will break the seal and you can usually twist them back and forth while pulling, and they'll come off.
89RS w/350 TPI; 69RS/SS w/450 HP 350/Muncie 4-Speed "Too weird to live, too rare to die."
Old Jan 2, 2001 | 03:10 PM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
Cut them off and replace them. Better now than later.
91 Formula 305 TPI Stock
88 Formula 350 TPI Stock
Old Jan 2, 2001 | 08:14 PM
Blue92's Avatar
Well I just keep pulling and they finally gave up. Thanks for the replies.
<A HREF="http://albums.photopoint.com/j/View?u=1229597&a=9072781&p=29492901
" TARGET=_blank>http://albums.photopoint.com/j/View?u=1229597&a=9072781&p=29492901
</A> Harder"
Stock 305TBI,
Eibach Sportline Springs,
Koni Struts and Shocks,
SSPE lower control arms and Panhard bar,
Hellwig Rear Swaybar and Energy Suspension bushings.Aluminum Driveshaft
Old Jan 3, 2001 | 11:25 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Just a quick observation, but i'm willing to bet that those of you advocating the 'try and twist/pull it off first' method have never actually had to replace a thirdgen heater core.
If those hoses don't come right off, do you really want to risk cracking either one of those thin pipes of the ****ty solder joints holding it together on the heater core. Is $2 of hoses really worth 6+ hours of completely dissassembling of your dash to replace it? Just cut the hoses off and save yourself a huge headache.
...ed
Old Jan 3, 2001 | 11:35 AM
John'89L98's Avatar
Well said, Ed.
Old Jan 3, 2001 | 12:59 PM
Pat Hall's Avatar
Hey Ed, just a little side note. I was replacing my heater core when I used the twist and pull method! I wouldn't recommend that method if you're not changing the core, especially considering the reason you end up having to replace your core in the first place is because GM was too cheap to use enough solder on their cores. I compared my replacement lifetime warranted core to the original and noticed it had about twice the amount of solder in the critical areas as the original one! Yeah, if you're just putting new hoses on, cutting the old ones is definitely the way to go.
[This message has been edited by Pat Hall (edited January 03, 2001).]
Old Jan 3, 2001 | 01:19 PM
Bort62's Avatar
I Have a nice Big Scar On My Left Shoulder To Always remind me To be Careful When Pulling Off Hoses When the Hood is On the Vehicle
be safe!
Old Jan 3, 2001 | 02:01 PM
lock's Avatar
Car: 86 IROC-Z
Engine: Superramed 355 w/ intercooled T72
Transmission: T56 -=- www.iroc-ss.com
did it just last night. These hoses are cheap. Not worth the hasstle of saving. I pulled out a razor blade. Give it a nice slice along where they mounnt on the heater core and it peals right off.
Mark Lock
- 86 IROC-Z - SuperRammed 383/T56
- -= IROC Online =- - The site dedicated to the IROC-Z
Pac J
May 17, 2020 10:44 AM
sheachopper
Jul 31, 2019 11:27 AM
