TBI 305 cranks but won't start??
Old Dec 7, 2003 | 01:08 AM
atryko's Avatar
Car: 89 firebird
Engine: LO3 TBI 305
Transmission: 700R4 auto
Cold morning...car cranked, turned over, stumbled bad, then died. Couldn't get it to do anything but crank after that. I hear the fuel pump prime when I turn key on. But what's weird, is that after I try to start (unsuccessfully) I hear the fuel pump continue to make noise for about 20-30 seconds after I turn the key off. Any ideas? Within the last few months I've had to replace the fuel pump & fuel filter, and I have a new battery. And I have had the typical code 32 (EGR) light for quite a while, just haven't had and trouble so I haven't fixed that yet. Could the EGR be a possible culprit? Any ideas??
Old Dec 7, 2003 | 01:30 AM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
Pull the lid off the air cleaner. Have someone crank the engine for you. Do you see fuel spray? Also, check for spark. If you have neither, you're looking at the pickup coil, or Ignition module. If you have spark but no fuel spray (and it sounds like your pump is working) you may still have a weak pickup coil. You may try sparying a bit of starting fluid into the TB and see if it starts.
The pump continuing to run is actually a good sign. It means that the oil pressure switch is seeing pressure, and turning the pump on, and it's staying on until the pressure drops back off...
pimp2303
Jul 27, 2017 02:03 PM
Jae992
Aug 27, 2015 09:07 AM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
Tonyy_z
Aug 12, 2015 07:20 AM
