Little problem...
Old Jan 3, 2001 | 02:33 PM
1984-Firebird-SC's Avatar
Car: 2002 Grand Am GT
Engine: 3400 V6
Transmission: Automatic
Little problem...
I have a little problem and I was wondering what you all thought:
Up here on cold days, the car doesn't quite run right. When the gas is applied to it, it sputters, but does, generally, rev up. This happens at idle and at rolling, sometimes with pronounced shaking in the car going down the road. After it's been driven for a while, the problem seems to clear up though... I'm no tech wiz, but it seems like it's not getting enough gas and therefore could be the fuel pump??? But that's why I'm asking you all here, so any input is appreciated!
Mike Davis 1984 Pontiac Firebird
2.8L V6 LC1
Camaro Z28 mag rims
Kenwood KDC-215 CD receiver
"Oh I've seen better days
The pain of these memories I cannot drive away" - Econoline Crush "Nowhere Now"
Old Jan 3, 2001 | 02:51 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Here's my quick shot at it, since I only played a bit with a 2bbl 2.8l carb...
The EFE grid between the carb and intake manifold could be beat up & not working. It's basically a heater grid that helps your fuel evaporate (Early Fuel Evaporation) better so the car runs better. This thing doubles as the gasket between the carb & intake. When I put a junkyard E2SE on a friend's '83 [edit: oops, had 84] Camaro, he needed to buy a new EFE grid. I think it was $30 or so?
Or, maybe the heat stove pipe has slipped off.. that's between your air cleaner "arm" and an exhaust manifold.
How's your fuel filter, by the way?
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
[This message has been edited by TomP (edited January 03, 2001).]
Old Jan 3, 2001 | 05:11 PM
Engine: 3400 V6
I also got a reccomendation to try gas line antifreeze to see if it would help at all, so I'll try it first, then take my car apart after
Old Jan 3, 2001 | 05:55 PM
Digger's Avatar
Perhaps the choke is sticking, that will explain the shaking and poor reving.
We'll get out of here, it'll just take a hole lot of floorin.
barbiek9
Sep 3, 2002 04:24 PM
FLYNLOW92rs
Aug 30, 2002 12:17 AM
Philou
Aug 18, 2002 01:29 PM
Blaze of Glory
Nov 20, 2001 10:18 AM
