clicking sound when starting the car???
Old Jan 4, 2001 | 01:27 PM
jm91rs's Avatar
I have had this problem for a while, when I turn the key to start the car I just hear a click sound and the car won't start. When I let off the key and turn it again it sometimes starts, sometimes it clicks again. Usually after trying 5 times it will start. I have to go through this process about every 10 times I start the car. I bought a new starter and put it on, but it did the same thing so i took it back. If it is a starter problem, maybe I the one I bought was bad too? I am in no hurry as I have had the problem for months and it isn't getting noticably worse. Thanks for any help.
Old Jan 4, 2001 | 01:32 PM
snakeskinner's Avatar
low voltage to the starter will make a click as you describe. Make sure your battery has enough amperage in it first off. I don't mean see if it has 12 volts, have someone load test it with a battery tester to see how many cranking amps it has. next suspect is the battery cables. check them for corrosion or rust and make sure they are tight. I bet one of these takes care of the problem.
Kyle Osterholt
Okarche, Oklahoma
ASE Master Certified
86 T/A 383 TPI
89 TTA #1002 T-top/Leather
89 TTA #1358 Hardtop/Leather
80 T/A Pace Car
73 Opel GT
B_Dubya
Aug 26, 2015 05:09 PM
86Base
Aug 8, 2015 01:34 PM
Sherpajames
Aug 7, 2015 06:56 PM
