PS pump stuck?
Old Dec 10, 2003 | 04:02 PM
middlebird's Avatar
Car: 86 Firebird
Engine: Carb'd 305
PS pump stuck?
I am trying to swap out the belts on my new to me bird and have gotten all the accessories to move except the PS pump. I'm pretty sure I got all the bolts I needed to to unsecure it however it still won't budge.
Any assistance would be appreciated!
Ethan
Old Dec 10, 2003 | 06:33 PM
ede's Avatar
ede
i bet you don't have all the bolts or brakets loose
Old Dec 10, 2003 | 06:53 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
One nut on the back, down low, below the one bolt you can see
Old Dec 10, 2003 | 10:12 PM
c45m's Avatar
Car: 1970 Formula
Engine: 400 .030 over
Transmission: M21
Man that sucks
I had the same problem not two days ago when I was replacing the water pump, and there is always that one bolt that you cant get. (the bottom one on drivers side) So I had to put the whole thing back together because I could not find the last bolt on the power steering pump to pull the pump off. So I could not get to the last water pump bolt.
Sorry had to add that.
Old Dec 10, 2003 | 11:43 PM
Vader's Avatar
Don't forget this one:
And this one:
And this one:
Old Dec 11, 2003 | 06:24 AM
middlebird's Avatar
Car: 86 Firebird
Engine: Carb'd 305
Thanks for the help guys... I got all three that Vader shows, plus one I didn't need The one I missed was the one on the drivers side down below that is in between the PS pump and the exhaust....
83 Crossfire TA
Jan 3, 2016 01:26 PM
Cameeeero
Sep 18, 2015 04:00 PM
backtothe80s
Sep 5, 2015 12:39 AM
JHX
Aug 29, 2015 02:30 PM
