Where's my fuel filter located??
Old Jan 5, 2001 | 12:36 PM
92GTA's Avatar
It's time for a tune-up
www.TransAmGTA.com
1992 GTA (226 made), 1 of only 18 "Dk. Jade Met." 92 GTA's, My Window Sticker, LB9, 700R4 4-Speed, T-Tops, Grey Leather, every available option except J65 and U1A.
Current Mods/Upgrades: 80 Series Dual Outlet Flowmaster, TPIS Air Foil, K&N Air Filter, and Mobil 1.
Future Mods/Upgrades: None but a complete restoration.
Best Track Time: 14.6sec@96.6mph
"If it ain't broke, fix it til it is!"
Webmaster www.TransAmGTA.com
My 3rdGen Firebird Message Board!
[This message has been edited by 92GTA (edited January 05, 2001).]
Old Jan 5, 2001 | 12:50 PM
KS91Z28's Avatar
I don't know if Firebirds are any different from Camaros when it comes to the fuel filter, but on Camaros, it is underneath the car on the driver's side. Right about where the back seat would be.
Old Jan 5, 2001 | 02:18 PM
I ROCK's Avatar
Car: 89 IROC-Z
Engine: LB9
Transmission: 700-R4
Yep - just did mine again last night. Jacked up the car by the differential, put jackstands under the axles. Take a coffee can or something to catch fuel, a 5/8 wrench, a 13/16 wrench, a 10mm socket and ratchet to loosen the filter holder, a couple towels, and probably a LOT of WD40 if it hasn't been changed in forever.
89 Iroc-Z LB9 305 TPI auto 2.73 posi:
3" Dynomax "cat" back,K&N filters, TB bypass, 3" pipe in place of cat, cleaned and flow-matched injectors, 180' thermo, mild ignition mods, synthetic oil, kicker sound system, soon to attempt engine swap...
Old Jan 5, 2001 | 02:28 PM
I ROCK's Avatar
Car: 89 IROC-Z
Engine: LB9
Hey 92, sweet car and cool page, but how come your RPO (LB9) indicates a 305 but the window sticker says 5.7L (L98)? Hmmm. It's a sweet ride either way, esp if you got a 14.6 with an LB9 in a car that heavy.
Old Jan 5, 2001 | 03:10 PM
92GTA's Avatar
Thanks man
If you look at the window sticker, it says that the 5.7L is "Standard" not equipped. It says on the right hand side that it was deleted as per the option for the T-Tops
92camaroJoe
Jul 29, 2023 07:57 PM
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
