Engine oil leak question
Old Dec 11, 2003 | 04:15 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
I have a small oil leak comming from around the timing chain cover/mech fuel nlock off plate/crankshaft area. I had the mech fuel pump gasket replaced and from what I can se it isn't comming from the timing cover. So I'm thinking it's from the crank seal. How easy is this seal to replace? What's involved and how long should I allow for a job like this?
The leak isn't bad, but the oil is being spread around due to it managing to get onto a pulley down there.
Engine's an 87 305 btw.
Thanks for the help
Robert
Old Dec 12, 2003 | 03:50 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You need to pull the harmonic damper, which requires a special puller and a tool to reinstall it. You can buy these tools, they aren't particularly expensive, or rent them. Some parts stores will loan them to you with a deposit.
Other than that, the actual seal replacement is fairly easy.
Old Dec 12, 2003 | 04:33 PM
hydric's Avatar
Car: 1985 Iroc-z
Engine: 355 sbc
are u sure u need a tool to reinstall it? i know when I pulled mine i used a triangular type tool to remove it, but i dont recall a tool to put it back on..
just wondering.
Old Dec 12, 2003 | 08:33 PM
five7kid's Avatar
You can bang it back on, but that's not good for the main thrust bearing.
The tool screws into the crank, and has a nut/washer that pulls the balancer on nice & easy. If you don't ask for the installer, you're not going to get it with the puller (typically).
Old Dec 12, 2003 | 09:02 PM
Vader's Avatar
Make sure you have a sealed bolt in the front of the block, just to the right of and above the crankshaft snout. This bolt hole is tapped into the block in the passage for the fuel pump push rod. If there is no sealer on the bolt, it can leak. If there is no bolt, it can REALLY leak.
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Navy8125
Aug 21, 2015 09:32 AM
redmaroz
Aug 16, 2015 11:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
drathaar907
Aug 6, 2015 04:20 PM
