Metallic oil on new shortblock
Old Dec 11, 2003 | 09:24 PM
PLANT PROTECTION's Avatar
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
So far all my oil changes on my new shortblock have had a metallic look to it. Want a few ideas on the cause. The block was blueprinted and the only spec that wasn't within tolerance was the rod side clearance, which was quite far off, don't remember the exact value but it was something like 5 thousanths tight. I asked on this before I finished building the remainder of the motor and most said that it could be from the new rods. Could this be the source? Also, don't know if this is related, but when I pulled the heads at 5k, there was still a crosshatch on all cylinder walls, is this normal. Thanks for any input.
Old Dec 11, 2003 | 09:59 PM
junkyarddog's Avatar
Car: 1999 Chevy Cavalier
Engine: 2.2
Transmission: 5 speed
Axle/Gears: it's part of the transmission
how many times did you change the oil? did you use 30w during the initial break in? did you use assembly lube where necessary?
I have a motor with 11k on it and the crosshash is still visible, that is a good thing!
can you hear any unusual noise when the motor is running, or feel anything from turning it?
Old Dec 11, 2003 | 10:38 PM
The oil has been changed 4-5 times, same look every time. Assembly lube on all bearings 75w-90 on cylinders and cam. 5w-30 on breakin primed before inital run. Short block sounds/feels normal, a little valvetrain noise but that started after a loose rocker @ ~3k.
Old Dec 12, 2003 | 07:52 AM
ede's Avatar
ede
send the oil out to be tested, only 20 dollars and you'll know what's in it and that may point you to where it came from.
Old Dec 12, 2003 | 08:01 PM
Do you have any more info on this? Should I look local or is there a place over the net?
Old Dec 13, 2003 | 07:37 AM
ede's Avatar
ede
blackstone labs ft. wayne in, they'll give you a free sample kit if you write them. look for their web site, my guess would be www.blackstonelabs.com
Old Dec 13, 2003 | 08:21 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
"something like 5 thousanths tight"
I don't know but tight doesn't sound good. Something tight is just gonna losen up and it could be what is going on.
That 5 tho tight is wearing away.
need to get a engine tech in here
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
tyeo098
Nov 30, 2015 06:27 PM
Doobie52
Sep 11, 2015 06:19 PM
Nick McCardle
Sep 10, 2015 08:36 PM
