How much $ to get starter millled?
Old Dec 13, 2003 | 01:30 PM
Rolly_Vera87T/A's Avatar
Car: 1987 Trans AM
Engine: 400 small block
Transmission: stock???
Does anyone know how much it costs to get the starter mounting block milled
Old Dec 13, 2003 | 03:09 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Why are you doing this? Is there some sort of a Problem you're attempting to fix this way? Exactly what motor and trans do you have?
Old Dec 13, 2003 | 03:26 PM
Car: 1987 Trans AM
the starter always messes up after a month or so of being repaired after that a grinding noise is heard everytime i try to start it... i have an 87 trans am with a 400 engine(from the 70s) it used to have a 305 LG4 with the auto transmission that i still have on the car
Old Dec 13, 2003 | 03:37 PM
Vader's Avatar
Before machining the starter mounting pad, I'd suggest mounting a starter without the field winding, manually engage the pinion, and measure the angle and clearances. You may have one of those blocks that has holes drilled/tapped in the wrong location, or may actually need only to shim the starter.
Make sure you use a NEW pinion and starter nose with NO WEAR.
Old Dec 13, 2003 | 04:19 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Also, are you using REAL starter bolts, not just some random ones out of your bolt collection?
Old Dec 13, 2003 | 07:33 PM
D_Amlee's Avatar
Car: 89 IROC
Engine: Yes
Transmission: That, too.
Also, when you check the pinion tooth clearance, rotate the flywheel around to a few different spots to see if the clearance is the same all around. Sometimes the flywheel gear can be pretty far out of round (due to damage, warpage, whatever). If this is the case, it would be easy to think you are shimming the starter correctly when in fact it could end up too tight or too loose depending on where the flywheel was when you checked the gear tooth clearance.
3rd gen money
Oct 11, 2019 09:57 PM
Gunner242
Dec 25, 2015 04:49 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
Jlanz55
Sep 29, 2015 08:55 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
