Auto Xray scanner reading says I am in first gear when I am not.
Old Jan 5, 2001 | 08:52 AM
john5.7 87Iroc's Avatar
Car: An '87 Italian Retard Out Cruisin'
Engine: LS1 install in progress
Transmission: 4L60e
Axle/Gears: 9 bolt
I just got the scanner and scanned my car today. Everything appears to be normal except the readings about what gear my car is in. The scanner list whether I am in park or neutral, Or whether first gear or fourth gear is engaged.
Whatever gear I really am in whether it be park, neutral, 1 2 3 or 4 the scanner always says first gear is "engaged". Then it lists park/neutral as "not detected" and fourth gear as "not engaged" when it really is.
What can be causing these bad readings?
1987 Iroc 350
GTS headlight/tail light covers
Camaro SS Wheels w/Sumitomo HTR ZII 275 rear, 255's in front
K&N filters
Adjustable Borla cat back
Large tube runners
ported plenum
Holley afpr
SLP 1 3/4" headders (not installed yet)
FUTURE GOAL:
To go really F'in fast!!!
Some pics of it at
http://albums.photopoint.com/j/Album...949&Auth=false
Old Jan 7, 2001 | 07:18 AM
SSS's Avatar
SSS
My car does the same thing. I have an 86 with an 87 PROM. The Auto X-Ray gives reversed readings on the transmission. When I put the 86 PROM in the readings are correct. I checked the 86 and 87 wiring diagrams and they are the same except for one wire. I wonder if it might be the internal wiring in the transmission. It does not seem to affect the way it runs. If I rev it to 3000 in neutral for a couple of seconds it set a code that indicates the speed and RPM do not match
jklein337
Sep 19, 2018 06:23 PM
gta90
Sep 15, 2015 04:00 PM
Electro_X
Aug 19, 2015 07:59 AM
mizz0313
Aug 12, 2015 06:45 AM
