how do I get the IAC valve off? please help asap
Old Jan 7, 2001 | 02:20 PM
twiztid's Avatar
the IAC valve I was hoping to check but the thing wont budge, any secrets I should know about??
thanks
Old Jan 7, 2001 | 02:29 PM
I ROCK's Avatar
Car: 89 IROC-Z
Engine: LB9
Transmission: 700-R4
Hmmm - worse case scenario is you take off the tb and put a crescent wrench on the iac and brace the tb for leverage. There's thread locker on the threads and that's why you're having trouble. If you've done the tb bypass, taking off the tb is not bad at all.
89 Iroc-Z LB9 305 TPI auto 2.73 posi:
3" Dynomax "cat" back,K&N filters, TB bypass, 3" pipe in place of cat, cleaned and flow-matched injectors, 180' thermo, mild ignition mods, synthetic oil, kicker sound system, soon to attempt engine swap...
Old Jan 7, 2001 | 02:49 PM
twiztid's Avatar
I took off the TB and there are a whole bunch of screws, should I take those off instead>
Old Jan 7, 2001 | 02:55 PM
twiztid's Avatar
can you get a gasket for the iac at autozone?
it just cracked all to hell
Old Jan 7, 2001 | 03:20 PM
Vader's Avatar
Twiz,
While you're there getting a gasket, get a small jar of anti seize compound so the IAC doesn't get stuck again. There should be no sealant on the threads - that's what the gasket is all about.
Later,
Vader
"I cannot take this any more... Saying everything that I've said before..."
Adobe Acrobat Reader 4.0
Old Jan 7, 2001 | 03:21 PM
twiztid's Avatar
thanks vad
Old Jan 7, 2001 | 04:42 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
The only way I know of to get the gasket is to buy the kit. It comes with the IAC housing gasket, IAC gasket, and the top plate gasket. GM still sells them, don't know about autozone. While it is apart, check out my version of the TB bypass TB Bypass
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey, 22# injectors,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
92firebirdguy
Sep 1, 2016 07:53 AM
earlpote
Sep 12, 2015 11:55 AM
greenyone
Sep 8, 2015 08:41 PM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
greenyone
Sep 2, 2015 03:39 PM
