Have any of you drilled and tapped a Victor Jr. for a vacuum port?
Old Dec 16, 2003 | 10:39 AM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
I need an extra vacuum port on my manifold for my pcv to hook to. The papers that came with the intake says to drill as close to the carb mounting flangs as possible. Too close looks to be an interferance with the carb and the runner is at an angle. I'd really like to see a pic of one already done. The intake is an Edelbrock Victor Jr. Thanks in advance.
Old Dec 16, 2003 | 10:45 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I've drilled lots of intakes for stuff like that. No pics though.
The trick is to use a center punch, and drill a small hole (like 1/16" or something) to start, at exactly the angle you want it to end up at; then drill it with successively larger bits until you get to the size you want, which would be whatever drill it is for ¼" pipe thread (I can't recall exactly... it should say on the tap). The small bit, then one about 3/16" or ¼", then the final size, should be enough steps.
Old Dec 16, 2003 | 11:04 AM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
Have you ever gotten too close to the divider in between the 6 and 8 runner? I don't want to drill through the middle of it.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
steimel94
Sep 20, 2015 12:46 PM
Night rider327
Sep 16, 2015 02:20 AM
dimented24x7
Sep 6, 2015 03:51 PM
