Disconnect knock sensor...bad idea?
Old Jan 7, 2001 | 08:50 PM
theformula's Avatar
I talked to Ed Wright and with my mods, he said I won't need a custom chip.
He said to go with his stage 2.
Heres my problem. When he custom tunes, he de-sensitizes the knock sensor so it doesnt think the roller rockers I have are fake "knock".
Since this is not a custom chip, the knock sensor will not be de-sensitized. Can't I just disconnect the knock sensor ? Is the knock sensor responsible for anything else besides listening for knock?
Thank you
91 Formula
305 TPI 5speed
1LE/G92/WS6
K&N, SLP airfoil, ported/polished plenum, March pulleys, TB coolant bypass,Crane AFPR(47psi),Crane Gold 1.6rrs,MSD coil,MSD6AL, Holley 9mm wires,Bosch O2sensor, SLP headers & catback,3:73s w/Auburn posi,180* t-stat,JET 195* fan switch, Macewen white face gauges, Autometer gauges, Zoom hi-performance clutch.
Street legal with stock throttle body, runners,intake manifold,cam, and heads.
Old Jan 7, 2001 | 09:16 PM
ede's Avatar
ede
don't think i would, but i've never had knock problems. i've read on here of people using a couple of wraps of teflon tape to help.
ICON Motorsports
1st & 3rd
Old Jan 7, 2001 | 09:30 PM
SSS's Avatar
SSS
When you start your car the computer advances the timing until a knock is detected. If the knock is not detected an error code will swt.
83 Crossfire TA
Jan 3, 2016 01:26 PM
greenyone
Sep 2, 2015 03:39 PM
masonta
Sep 1, 2015 06:40 PM
Thaney9
Aug 29, 2015 03:16 PM
