Does this sound strange to you or is it just me?
Old Jan 8, 2001 | 10:18 PM
Drkhrse89's Avatar
Car: 89 Iroc
Engine: 305TPI
Here is the story, every time I go over a bump or pot holes while flooring it I loose power and the car jerks rather violently. I really dont know any other way to explain it outside the way I just did. Does anyone have any ideas what may cause this or like I said is it just all in my mind. Thanks for the help.
Member of NCTGA
North Carolina Third Gen. Assoc.
'89 Iroc-Z
305 TPI few minor things
5 speed
Lowered 2" and yes it is a pain to drive
Old Jan 8, 2001 | 11:02 PM
Vader's Avatar
Dark,
I'd start looking for poor connections at the ignition coil, pickup coil, HEI module, and make sure the distributor cap is secured in place. Those little hook/tabs can be a little less than a positive connection at times.
The rotor might also be bouncing around.
It's also possible that some of the engine ground straps and cables are loose and breaking connection on the washboards. The same could be true of nearly any electrical connector, including those at the ECM, EST, firewall bulkhead connectors, fuse panel, battery cables, starter and alternator - you get the picture.
Worst of all, it could be some component(s) working loose inside the ECM, making intermittent connection when the bumps are encountered.
If you notice other electrical systems losing power, like the lights flickering on bumps, it might narrow down the problem.
Later,
Vader
"I cannot take this any more... Saying everything I've said before..."
Adobe Acrobat Reader 4.0
Old Jan 8, 2001 | 11:19 PM
Enkil's Avatar
Maybe you're just breaking traction?
89 iroc-z 305 tbi
everything stock, except for a mirror that fell off
Fanatic1074
Oct 3, 2022 05:57 AM
RS Reaper
Oct 17, 2018 07:52 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
wanext
Oct 6, 2015 12:18 AM
Fanatic1074
Oct 2, 2015 03:47 PM
