check engine light comes on after sitting at light for a minuite
Old Jan 8, 2001 | 10:03 PM
B84305-Streetmachine's Avatar
when i sit at a light for a minuite or two.....the check engine light comes on....when i drive away ...it goes back off......please help...
Old Jan 8, 2001 | 10:07 PM
Vader's Avatar
B84,
Scan for error codes to determine what the ECM is warning you about.
Check this file for instructions and decoding:
GM Error Codes.pdf
You'll need Adobe Acrobat Reader to open/print the file.
Later,
Vader
"I cannot take this any more... Saying everything I've said before..."
Adobe Acrobat Reader 4.0
Old Jan 8, 2001 | 10:17 PM
thanks vader.....power of the darkside!!!!
any guesses as to what it may be?
Old Jan 9, 2001 | 01:16 AM
formula90's Avatar
Car: 1990 Formula
Engine: 5.7 liter
check your codes and go from there
I have experience...unfortunatly,its a result of bad judgement.
click below to check out MY FORMULA PAGE!
http://www.formula350.com
or click below to email me
astralbaby11@hotmail.com
Old Jan 9, 2001 | 06:20 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
My guess: Low oil pressure.
Old Jan 9, 2001 | 09:09 AM
Big Money Mike's Avatar
I had the same thing happen on my 95 TA. It turned out to be a bad O2 sensor. Might want to check that out. Oh, and dont run your car up to 120 with this problem, I did and my car died.... Not easy to slow down and steer at 120 with power nothing!
Mike D.
Old Jan 9, 2001 | 10:08 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
My 85 IROC does something similiar but only on start up. After I've driven a block, the check engine light goes off. I BELIEVE the code was 24--at any rate it had something to do with the VSS. If I remember correctly, the manual said to disregard the code/light if the rear wheels weren't moving. What's that all about? Vader?
JamesC
[This message has been edited by JamesC (edited January 09, 2001).]
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Omega
Aug 10, 2015 12:46 PM
