HELP!!! Car runs rough and worse
Old Jan 7, 2001 | 06:35 PM
Neo's Avatar
Neo
My car is crapped. Today I replaced the spark plugs, wires, distributer cap,, replaced the positive battery wire (ground wire was bad) put on a chrome valve cover (only had time for one). When I was doing this I accidentally broke the heater control valve. Now it rides rough and has antifreeze coming out my exhaust. I am sure the dist. cap is tight. I am also quite sure the spark plug wires are fine. I clamped off the feeding hose to the valve. (It has three hoses going to it, two from the heater.)
My questions are: Can I reroute the hoses to the valve? How is antifreze getting in my exhaust? And does anyone have pictures so I can make sure I hook everything back up correcty? Any additional things anyone can think of or help with would be EXTEMELY helpful.
EDIT:It also backfired a few times when I gave it gas out of the Throttle body itself. I also shot out white clouds of both the throttle body and the exhaust.
Mike Kenny
Current: 1991 RS 305 TBI
Past: 1990 RS 305 TBI (A woman forgot what red lights are for)
Current: mostly stock - newer 305 w/ 12,000 on it
Eclipse speakers all around w/ 10" tube powered by a Alpine V12 in back
K&N filter w/XStream flow lid - It is sweet!!
Future: 2" Cowl hood
[This message has been edited by Neo (edited January 07, 2001).]
Old Jan 7, 2001 | 07:30 PM
SGT SWEETPANTS's Avatar
It sound like you have some serious problems. Are you absolutely sure that it is antifreeze coming out of your exhaust. I am going to step out on a limb and guess that maybe you did not hook the spark plug wires back to the right cylinders. That would make it run terrible, backfire throught the carb and possibly have som unburned fuel running out the tail pipes. If that is not the case, I have no idea what the problem is. Good luck my friend.
'86 IROC-Z, 305 LG-4, T-5, T-Tops, 50k Original Miles, K&N Air Filter, Jet chip, KYB Shocks/Struts, Centerforce Dual Friction, B&M Ripper Shifter
Old Jan 7, 2001 | 10:53 PM
Neo's Avatar
Neo
I am pretty sure it was antifreeze but I only noticed this after I moved the car, so it might not be (praying). I made sure that I hooked the wires in the correct spots, but is there a way to check that they are in the correct place?
Old Jan 8, 2001 | 02:29 AM
zroc's Avatar
Car: 87 IROC
Engine: LB9 for the moment
get a repair manual to ref the number one position on the dist cap... it will have the firing order as well... 1,8,4,3,6,5,7,2... trace the wires to the appropriate plug position... that should get you fixed up...
zroc...
Old Jan 8, 2001 | 10:07 AM
Neo's Avatar
Neo
Anything I should know/do? I will out in a hour or two and get a new heater conrol.
Mike Kenny
Old Jan 8, 2001 | 08:33 PM
84TransAm's Avatar
Perhaps the problem lies in the Distributor cap, i know this sounds wack, but you could have not matched it up properly, there is a notch that fits onto a groove on the Distributor, these 2 go together. Happend to me caused me tons of trouble, and turned out to be a quick fix. Even though i thought the distributor was shot, ignition wires were defective, etc... Takes like 5 minutes to fix at most if this is the case.
--Steve S-- 84 Trans Am 305 (cough)LG4(cough), 5 speed, Flowmaster 80 series, otherwise an emissions restricted slow 150 hp(chilton rating) 240 torquer that needs RELEASE!!!!
P.S. Daily Driver
Old Jan 8, 2001 | 09:38 PM
Vader's Avatar
Neo,
If you're not certain they're correct, go back and check.
Later,
Vader
"I cannot take this any more... Saying everything I've said before..."
Adobe Acrobat Reader 4.0
Old Jan 9, 2001 | 10:45 AM
Neo's Avatar
Neo
I did have 6 and 3 backwards and a vacuum line not hooked up thank you for all of your help.
kyleb24
Aug 15, 2015 08:24 AM
ZZ42Fast
Aug 10, 2015 08:20 PM
Kaweh
Aug 9, 2015 02:54 PM
Sherpajames
Aug 7, 2015 06:56 PM
