How far on does the crank gear go?
Old Dec 20, 2003 | 11:21 PM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
I am installing a timing chain set on my 88 TPI.
do I push the timing gear on all the way to the crankshaft stop or is there a distance I should install it to?
Old Dec 20, 2003 | 11:41 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It should seat against the shoulder behind it on the crank.
Heat it up in boiling water or a 300 degree oven before you put it on, it will go on much easier.
Old Dec 21, 2003 | 08:12 AM
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
thanks!
gixxer92
Sep 1, 2015 04:32 PM
Dialed_In
Aug 20, 2015 01:45 PM
mizz0313
Aug 12, 2015 06:45 AM
