Valve cover still doesnt fit
Old Jan 9, 2001 | 03:04 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I grinded the hell out of the new cover and I still cant get it between the top of the rocker and the Large Tube Runners. I cant put valve ocer first because i cannto get to the bottom bolts of the new runners. I played around in every angle for 3 hours today in 20 degree weather. when i take the cover pack off i see dents and shavings on top of every rocker arm WHAT DO I DO?
Old Jan 9, 2001 | 03:26 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Are you sure you have the valve covers turned the right way? That is, they have a definite intake side and exhaust side... if they're different the intake side will be slightly more vertical, and the more sloped-off exhaust side will hit the rockers if it's backwards. Not all VCs are like this; stock ones are though, and alot of others. Just something to check.
MoJoe
Sep 24, 2015 09:12 PM
NBrehm
Aug 25, 2015 11:49 PM
g.l.mos
Aug 22, 2015 12:02 AM
1985chevydude
Aug 20, 2015 12:29 AM
mustangman65_79
Aug 8, 2015 01:18 AM
