An odd problem
Old Dec 22, 2003 | 10:31 AM
Red_Demon's Avatar
From: Currently State College Pa, Usually, I live out side of philly.
An odd problem
Ok so my car will start normal and everything, but once and a while I turn it on and the RPM varies. It goes up to like 3000 rpm and then drops to like 400 rpm. and it keeps doing it.. It eventually (if I don't hit the gas) stalls out. Eventually it'll stop, I'll get a service engine light which only shows a "coolant temp" sensor error, and then it runs normal again.
anyone experience this and what was happening?
If I hit the gas while it's doing it's bouncing the car starts smelling like a lot of excess gasoline.
Let me know if you guys know anything.
-Justin
Old Dec 22, 2003 | 11:00 AM
BadBlue91RS's Avatar
Car: 1991 Camaro RS
Engine: Briggs & Straton
Transmission: Centrifical Clutch
From what I understand, the coolant temp sensor can cause all sorts of things to go heywire.
Change the sensor and the problem SHOULD go away.
Good luck with it man.
pjsparts
Oct 29, 2025 06:39 PM
383cam
Sep 9, 2015 06:01 AM
Fronzizzle
Sep 8, 2015 12:10 PM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
