So.... Are automatics' worth putting money into? New engine? etc.....
Old Dec 22, 2003 | 05:35 PM
KBeez's Avatar
Car: 88 Camaro S/C
Transmission: 700-R4
So ummm, I've thought about this a while, and decided I wanted an automatic. That's what my car is right now, but I had to decide between an '82 manual, and an '88 auto, and I went with the auto.
But my question is is it worth it to drop alot of money into it and build a new engine for this auto, or is it more of a lost cause as anybody with the same horsepower as me, with a manual is going to get more power to the rear wheels. Or should I just not worry about that, as an auto will probably beat it in the long run as it shifts much quicker?
Me and my dad are rebuilding a 350 .30 over and it's gonna be pretty modestly powerful.....
and btw, the reasons I wanted an auto are, for one, having a remote start, once you have one, you realize how much they really really help. And two, as it is a car I'll drive alot, I just wanted to sit back and press the gas, but I do admit a manual can be more fun.....
anyways, maybe this is a dumb question, but thanks for any help
Old Dec 22, 2003 | 05:42 PM
FruityOne's Avatar
Car: 1989 TransAm GTA
Engine: One sweet modified 355 TPI.
Transmission: The kind that shifts....
I'd go manual, but thats just my opinion because the GTA is the fun car. I have a winter car that i can drive around in and move crap with.
As far as automatics go? They aren't that hard to build up if you have a little knowledge and a decent budget. Experience still pays, but you can build a tranny that will take the abuse a modifed 350TPI puts out without too much money or hassle.
However, if you really want to build something strong, just buy a Pro-built tranny, or equivelent. You get what you pay for, and they are great trannies.
Old Dec 22, 2003 | 10:07 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Well, I really like my 700R4 in my '87 IROCZ. The tranny is pretty solid and shifts great, hard & quick, spinning the tires going into 2nd gear. Also, at the dragstrip, the burnout is easy and launches are much better. It is easier to get the auto to run well at the dragstrip in a consistent manner and you load up the gears when you power brake it. This saves on the rear gears and the axles.
I have an M6 in my '99 SS.. It is much harder to get it right at the dragstrip. I have to work on my launch technique alot more here.
Old Dec 22, 2003 | 10:08 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
You can build up a 700R4 pretty strong! You can even build it so you can manually shift when you want without worry of hurting it. So lazy when you wanna be, or shifting when you wanna be
jhawkeye
May 25, 2022 06:33 PM
camaro11j
Sep 19, 2018 08:49 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Exxon Limited
Aug 9, 2015 08:13 PM
