rocker arms question
Old Dec 27, 2003 | 12:45 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
When choosing a rocker arm for my soon to be engine build I see this:
SB-Chevy 1.5 Ratio 3/8''
SB-Chevy 1.6 Ratio 3/8''
theris 1.5's and 1.6's
who is nice enough to explain the difference? thanks!
Old Dec 27, 2003 | 12:48 AM
87350IROC's Avatar
Car: 87' IROC
haha, i guess its my night to help you out. 1.5 is standard length. the 1.6 ratio will increase the lift on the cam a little. when buying rockers get the full roller rockers, they free up some hp by reducing hp.
Old Dec 27, 2003 | 12:54 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Crane Cams Roller Rockers
STeel Tip
SB-Chevy 1.6 Ratio 3/8"
Item # 270-11807-16 1 x $179.99
do these look like a good candidate?
www.jegs.com
270-11807-16
type in that number to get the full details.
if increasing the ratio a bit isnt gonna hurt anything, why are they the same price as the 1.5's?
and i really appreciate your help tonight btw. Im really trying to figure out how imgonna build the engine. and I dont want to make any mistakes the first time around!
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
once agian. "Search"
1.5 or 1.6 is the ratio that the rocker arm increases the vavle lift of the cam.
1.5:1 or 1.6:1.
so a cam that lifts the vavle .500" w/ 1.5 rocker arms (standard), the came lobe only lifts the pushrod .333"
the rocker arm then increases the lift. so with a 1.5 rocker arm it is .500 with a 1.6 rocker arm it would be .533" lift.
obviously every cam is different.
most people find a little more power with 1.6 rockers than 1.5.
but roller rockers tend to make a big differnece.
but yeah... SEARCH
Old Dec 27, 2003 | 01:15 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
I have tried a search before every post, but its just not helping (too many posts out their with the words im searching for somewhere in someones post/reply)
anyways, i found these self aligning rollers' with 1.5 Ratio 3/8" stud
i think i would rather use self alligning then guideplates.
Old Dec 27, 2003 | 08:58 AM
ede's Avatar
ede
you ought to be able to tell by looking that 1:5 or 1:6 is a ratio just like 4:56 is. 1.5 is factory sbc rocker ratio. the stud diameter is the diameter of the stud the rocker sits on.
SLNTSCPE
Aug 22, 2015 09:15 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
Cameeeero
Aug 20, 2015 03:06 AM
redmaroz
Aug 16, 2015 11:40 PM
