guideplates
Old Dec 27, 2003 | 12:41 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
guideplates
When do you need guideplates?
how is it possible not to have to use guideplates? thanks!
Old Dec 27, 2003 | 12:49 AM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
do a search.
i look down the Tech board and i see 6 post by you all that could be answered by doing a search. you'll find it easier and quicker to do a search for any questions you have, because most likely its been asked before.
as for guidplates.
if your pushrods fit tight inside the head(no side to side play at all)= no guidplates needed.
if you have a narrow slot for the pushrod or a large slot for the pushrod= guideplates or self-aligning rocker arms.
you have to have screw in rocker studs to run guideplates (which is a good idea anyway).
and if you run guideplates make sure to get hardened pushrods.
sorry if i'm coming off rude, everyone here is plenty happy to help, but trust me, you'll find it very hard to get every answer you have on your hot-rodding journey, if you post every question, and don't do a search first.
87350IROC's Avatar
Car: 87' IROC
you need guideplates if have non-self aligning rockers, you don't use them if you have self aligning rockers
Old Dec 27, 2003 | 12:56 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Actually I have searched but maybe I just suck at wording the search, but I always get hundreds of posts and its hard to read thru it all.
Old Dec 27, 2003 | 09:00 AM
ede's Avatar
ede
you need guide plates when you have no other method of locating the push rods
LT1Formula
Aug 20, 2015 09:36 PM
PLANT PROTECTION
Apr 12, 2003 09:40 PM
PLANT PROTECTION
Jun 15, 2002 09:10 AM
martyr
Mar 27, 2002 01:42 PM
BranT
Nov 30, 2000 02:59 AM
