valve stem seals
Old Jan 11, 2001 | 02:18 AM
hungry4des's Avatar
Car: 89 IROC
Engine: 5.7 TPI
valve stem seals
Hey guys! I plan on changing my valve seals tomorrow and I wanted some tips from people that have done it.
The parts guy only gave me little black rings for the exhaust valves. He gave me little black rings and rubber cylinders with metal rings around them for the intake valves. Is that right?
Also, what does the best tool for taking off the springs look like? I would like to use the one that is easiest.
One more thing, how do I re-adjust the rocker arms after the springs are put back? I have the L98 engine in my 89 IROC. I think the lifters are hydralic-rollers from the factory if I'm not mistaken.
I have to drive 500 miles the day after tomorrow and I wanted to get this done before I leave. Any help would really be appreciated. Thanks.
Old Jan 11, 2001 | 03:13 AM
I ROCK's Avatar
Car: 89 IROC-Z
Engine: LB9
Transmission: 700-R4
here's the new website for the Best Damn Garage on the Net - he has an article all about changing valve seals and setting valve lash. It's a great site and I'm glad someone finally posted where he moved to I had looked everywhere!
http://www.racer-x.f2s.com/
89 Iroc-Z LB9 TPI auto 2.73 posi:
3" Dynomax muffler, K&N filters, TB bypass, 3" pipe in place of cat, cleaned and flow-matched injectors, accel 300+ wires, cap&rotor, synthetic oil, flexlite transmission cooler, afpr, !air pump&diverter valve, kicker sound system, soon to attempt engine swap...
Old Jan 11, 2001 | 08:49 AM
ede's Avatar
ede
i'd say the umbrella seals are for the exhaust since thet take more abuse. i use both umbrella seals and the o ring type seals.
ICON Motorsports
1st & 3rd
Old Jan 11, 2001 | 09:09 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I'll differ with ede on the seal application... the umbrella seals go on the intakes, because that's where oil can leak into the engine the most because there's vacuum there constantly trying to suck oil past the guides. If the exhaust valve stem leaks, it will be in effect the same as blowby; exhaust gas, being at a higher pressure than the crankcase will leak that way, not so much oil leaking into the exhaust.
Bubbajones_ya
Jul 6, 2024 08:32 PM
355tpipickup
Sep 13, 2015 11:35 PM
bamaboy0323
Sep 12, 2015 07:14 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
tgp1990
Sep 4, 2015 06:24 AM
