Volumetric Efficiency
Old Dec 29, 2003 | 04:54 AM
jrg77's Avatar
Car: '85 Camaro
Engine: LG4 305
It is wise to build a street car for VE? Can it be done? How?
Old Dec 29, 2003 | 07:36 AM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
i recomend building everything for a high v.e. how is alot of explaination though. too much typing for me.
Old Dec 29, 2003 | 07:53 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
you want every motor you have to have high efficency... its good for economy and power.....
how you go about doing it is the question...
athough i think you're talking about making your motor tweaked out to run near (or even over) 100% VE at 6500-7k probly means the car is going to be very inefficent outside that range.. like in low RPM street driving..
Old Dec 29, 2003 | 08:30 AM
jrg77's Avatar
Car: '85 Camaro
Engine: LG4 305
So VE up high is the enemy of VE down low? So can VE be achieved at any appreciable point where its benefits could be realized on the street?
Old Dec 29, 2003 | 08:34 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
no.
not all the time.
for example, a roots blown motor can have over 100% VE everywhere...
or a properly chosen modern cam can work over a broder range then a old school one...
its just harder to make the motor work over a broder range then in one small specific one. harder, not impossible.
Old Dec 29, 2003 | 08:46 AM
jrg77's Avatar
Car: '85 Camaro
Engine: LG4 305
This almost makes it sound like it could be directly related to cam choice.
Old Dec 29, 2003 | 08:49 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
more like the engine as a whole, but yes the cam has alot to do with where its efficent......
Old Dec 29, 2003 | 09:00 AM
jrg77's Avatar
Car: '85 Camaro
Engine: LG4 305
I suppose that it is limited by the part of the system that flows the least cfm. So if one could match the whole system to a flow number and then time the whole thing to get that flow then it would be achieved. I can see where the broad range aspect comes into play. Too bad we can take advantage of variable valve timing.
How closely to the various parts flow anyway? What typically is the weakest link?
92projectcamaro
Sep 12, 2015 12:33 AM
Lionsden
Nov 27, 2001 08:21 PM
rockind78
Jul 31, 2001 05:09 PM
jRaskell
Jul 31, 2001 04:50 PM
Pablo
16
Jan 10, 2001 11:06 AM
