Roller Lifter Rebuild.
Old Dec 29, 2003 | 11:03 AM
dennis6's Avatar
Car: 1991 Camaro RS
Anyone have any information on rebuilding or upgrading stock roller lifters?
Old Dec 29, 2003 | 11:10 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
2 easy steps:
1. Throw old ones away.
2. Buy new ones.
They're too cheap to be bothered, so they're not made so that it's possible.
That's one of the selling points of the better-quality racing ones; is that they are designed to be rebuildable, although not in the field. Factory only.
Old Dec 29, 2003 | 05:16 PM
GASGZLR's Avatar
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
I took apart my old 195,000 mile rollers and had them vat cleaned by the machine shop then I dissasembled each one and cleaned each component. They work fine but I just did it cause I was desperate to get the HOT cam in before the track closed.
Old Dec 29, 2003 | 06:03 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Sure you could do that, just basically clean them up; that's not "rebuilding" them though.
But, as long as the oil has been changed regularly, even that much work usually isn't necessary. Most of the time you can just re-use them as they are. If the roller part is damaged or worn, they just need to be replaced.
I know of no particular "upgrades" that can be performed on them.
Old Dec 30, 2003 | 01:56 AM
dennis6's Avatar
Car: 1991 Camaro RS
Thanks for the help. I don't really consider150 dollars cheap. Wish I was in position to consider that cheap.
Old Dec 30, 2003 | 07:00 AM
Pat Hall's Avatar
Just like RB said, unless the roller part is damaged in some way, there's probably nothing wrong with re-using the set you've got, so why worry about $150 for a new set?
KO1
16
Oct 15, 2015 05:00 PM
skinny z
Oct 5, 2015 06:23 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
Derrick86
Oct 1, 2015 05:12 AM
6998poncho
Sep 25, 2015 02:56 PM
