No start
Old Dec 29, 2003 | 02:46 PM
ponykiller92's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Transmission: Built 700r4
No start
Ok, when i turn the key, the motor is not turning over, and there is no sound from the starter whatsoever. I have all the bells and whistles. I just put in a gauge cluster from a 91 Z, and it started fine before that. Could this be something to do with the new gauges?
Old Dec 29, 2003 | 03:02 PM
CEP89's Avatar
Car: 89' IROCZ
Engine: 5.7 L98
Did you disconnect your battery while you swaped out the cluster? Do you have power to your other lights, etc.? Do you have a multimeter to check for voltage? Start with your battery and follow the cables back? Are there any left over wires that did not connect to anything on the new cluster. If all this checks out ok try swaping in your old cluster back in, and check to see if it starts. It might be something unrelated.
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
