timing ?
Old Jan 11, 2001 | 03:00 AM
91RamAir Formula's Avatar
Car: 91 Formula
Engine: 383 HSR
Transmission: 5th 700R4
Axle/Gears: 3.89
timing ?
under what condition should the ECM provide the most advance? And about what should the total advance be at WOT? I read sompthing about 36deg. but did not know if this was total timing under load or what.
Thanks any help would be appriciated.
Marc
Old Jan 12, 2001 | 02:12 AM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
Part throttle cruise conditions have the most ignition advance to give the best fuel economy.
WOT timing varies based on the engine mods. Most figures I see are in the 36 degree range at WOT.
The part throttle cruise timing is somewhere around 10 degrees more that the WOT.
My TPIS Stage V Prom only has 28 degrees of timing in Power Enrichment Mode, WOT according to Diacom.
Jake
1986 Corvette Coupe, 415 CID, Edelbrock 6073s, ZZ9
[This message has been edited by JakeJr (edited January 12, 2001).]
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
