Roller cam bearings?
Old Dec 31, 2003 | 06:19 PM
SweetS10v8's Avatar
Car: '89 Formula 350 & '86 Z28
Engine: L98 & 355ci
Transmission: 700r4 in both
Does anyone know what Busch series cars run, sb2s?
I picked up a cam, bearings, retainers, and springs off of a Busch car just to have it. The cam is a lot bigger around than a typical sbc, but what I wouldnt it be nice to have roller cam bearings like these..
Edit: Also, does anyone know if you can somehow bore where the cam goes in, in a typical sbc. I dont know how much material there would be in that area
Old Dec 31, 2003 | 10:59 PM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
Yes, in one of my old car mags (can't remember which one) there was tech article about boring SBC cam bearing journals for roller bearings. BUT, I don't know if it was for the Busch type cams or not. Either way, it is a pretty involed process that the whole motor needs to be taken down to the bare block for.
Tom
Old Jan 1, 2004 | 01:30 AM
Morley's Avatar
Not to mention, those bearings were never meant for a street engine, they'd have to be able to last 100k miles to be considered "streetable".
Gotta remember that a race engine is only going to run 500-1000 miles before it is torn down and all moving parts replaced.
Old Jan 1, 2004 | 07:06 AM
ede's Avatar
ede
seems to me a long time ago stock sized roller cam bearings PNs and how to was posted here. still had to bore the block over sized but you could use a stock cam. at the time i thought it would be trick to move the cam upward, or offset bore the block for more rod clearance around the cam with a longer stroke engine. no idea if it'd work or not but it's something that "ought" to work. even .060 off set would help rod clearance.
Old Jan 1, 2004 | 07:30 AM
SweetS10v8's Avatar
Engine: L98 & 355ci
anyone have a cam laying around in the garage they can go measure??? This one is 1 15/16" accross. I found the grind number on the end and was able to find it on Crower's website Cam Card
Part Number/Work Order Number E23622
Engine Application 350 CHEVROLET
Grind Number SPL 50MM JOURNALS
246/268 @.050
.537/.573 lift with 1.5 rockers, but its intresting that when designed they intended it to to run with 1.9 Intake and 1.8 Exhaust
Old Jan 1, 2004 | 07:56 AM
SweetS10v8's Avatar
Engine: L98 & 355ci
nevermind, I found it. Apparently this is for a Chevy rocket block...
50mm
But this does say you can get roller bearings for (close) to normal cams also
Old Jan 1, 2004 | 09:22 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
http://www.compcams.com/catalog/334.html
junkcltr
Aug 2, 2019 11:12 PM
anesthes
Mar 10, 2016 10:35 PM
gixxer92
Sep 1, 2015 04:32 PM
anesthes
Aug 26, 2015 01:37 PM
