Pulling an engine at the junkyard
Old Dec 31, 2003 | 09:42 PM
jrg77's Avatar
Car: '85 Camaro
Engine: LG4 305
I am getting a 350 from a Suburban. It is carbed so I shouldn't have too much trouble making it replace my 305 directly. I have never done this so I have some procedural questions.
So far I have taken off the six bellhousing bolts, the four torque converter cover bolts, five of the six y-pipe to exhaust manifold bolts, and three flywheel bolts. I think I stripped the exhaust bolt. What can I do?
I think my next move is to undo the engine mount bolts, but I wonder if I should get the hoist and hook it up first. The mounts seem to have a nut one size and the bolt on the other side a different size. Is that right? The bolt is a 5/8", and I think the nut is 11/16. What is the best way to get these done? Keep in mind I don't have an impact wrench to zip them out.
Is that everything I can do under the truck? What's up top than I have to plan for? To what do I connect the hoist?
Thanks,
Jason
Old Dec 31, 2003 | 10:24 PM
87350IROC's Avatar
Car: 87' IROC
For the stripped bolt you buy a special socket from sears to get it out, or you can drill it out. Support the engine with the hoist before undoing the motor mount bolts. I found that a 1 ft extension on a rachet was good for the nut or bolt on the back side of the engine mount and either a box wrench or another socket for the front bolt. I think that is how i did it. The best was to hoist a carbed engine is with a carb plate. Part number SUM-G1015 on summit racing. You take the carb off and attach that plate to the intake manifold. Or you can attach the chain to intake manifold bolts.
JP
Infested
May 22, 2018 11:56 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
ZONES89RS
South Central
Aug 14, 2015 09:07 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
matthew911
Aug 12, 2015 09:38 AM
