What is the point of gear drive?
Old Jan 13, 2001 | 04:06 AM
evilho7810's Avatar
Is it more reliable and accurate or do guys just use them to sound cool?
Old Jan 13, 2001 | 05:32 AM
raven350's Avatar
Car: '89 Pontiac Firebird
Engine: 5.7L
Axle/Gears: 10-bolt w/ 4.10 and Eaton Posi
All of the above...
You do not have any slack between the gears so it makes it more accurate. You will notice less jumping of the timing mark when you doing timing. The line on the is perfectly straight when you set timing.
And the whine noise is partially machined into the gears and partially just from two gears meshing together.
I have had a gear drive on my car for years and I have never had a problem.
Another good point is that you never have to worry the chain jumping a tooth.
I hope this helps....
And install is straight forward and easy.
Sportsman II 72 CC heads, Pete Jackson gear drive, Performance Resources chip, Edelbrock 1 5/8" headers and Edelbrock cat back exhaust, hi-flow cats, Trans-go stage 3 shift kit, Vigilante 9.5" 2800 stall convertor, SLP cold air induction, SLP roller camshaft, 24lb ADS injectors, AFPR, 3.45 rear end gears, and other goodies...
raven.com
jklein337
Sep 19, 2018 06:23 PM
gta90
Sep 15, 2015 04:00 PM
ezobens
Aug 19, 2015 10:29 PM
