Rocker Studs, different lengths?
Old Jan 1, 2004 | 04:01 PM
CamaroFreak87's Avatar
Car: 1987 Camaro IROC Z-28
I'm trying to buy a set of heads, and a guy near me has a set forsale for cheap. I have a '87 350 with a hydraulic roller cam(SLP running about .510" lift with my rockers). The guy said that the rocker studs for roller cams are longer than the studs for tappet cams, and these studs were for a tappet cam. The springs are good for a .550" flat tappet cam. So...would this rocker stud/spring combo work with my cam?
Thanks all
Old Jan 1, 2004 | 04:05 PM
ede's Avatar
ede
the studs are the same length, if the heads have longer looking studs it's because they pulled out. not likely springs for a flat cam will work for a roller. if the springs are used i'd either have them checked or trash them and buy new to match my cam.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
New2Chevy
Sep 28, 2015 12:35 AM
Billyadams
Sep 22, 2015 08:25 AM
355tpipickup
Sep 13, 2015 11:35 PM
