exhaust popping... wtf
Old Jan 1, 2004 | 10:02 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
so I've got hooker 2055s, no catalytic converter, and a 3" hooker catback. Very very minor insignificant exhaust leaks are possible. When I'm on the highway, and I go from 2500 rpm down to about 2000, I occasionally get a pop from the exhaust pipe... I haven't checked my timing lately (ever, lol) and I was wondering if that just came out of tune.
I've also got a 32 EGR problem, ever sicne my header install. Is this linked? The popping started when I got my 2055s on... Do you think a new EGR will solve both problems?
Thanks for input.
Old Jan 1, 2004 | 11:49 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
IIRC the pop is fuel being burned off with too little timing on decel. The 20:1 or so fuel mixture on decel may also play a contributing factor to this. Its normal and now that you have an aftermarket exaust youll hear it much more clearly. The solution is to run more timing where the engine is at high rpms and low map and the pop will go away.
The egr code is probably due to the reduced back pressure that you now have with the aftermarket exaust. Some egrs need back pressure to operate properly. The ecm goes to deactivate the egr but now that its not circulating exaust gasses it no longer sees a pressure drop in the intake manifold so it sets a code.
86White_T/A305
Mar 6, 2016 01:48 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
BOOT77
Sep 16, 2015 08:37 PM
gta892000
Sep 16, 2015 12:37 AM
DARKmj16
Sep 9, 2015 04:07 PM
