My engine Is not making REV's above 4000RPM...any ideas?
Old Jan 11, 2001 | 04:21 PM
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
Hey guys. Heres the problem. My 1987 TA GTA, had a MAF crap out last summer. It was original. I changed it with the wells model which im sure most of you are familiar with. Anyway since the swap, my car has developed some sort of hic-up. I can't get the engine above 4000RPM when it's cold. (I mean engine cold not outside air temp). This happens in any gear and in Park or Neutral. It will not rev over 4000. If you put your foot to the floor it starts bacfireing and farting and popping, the car starts surging like someone driving a standard bad. Sometimes I can Smell raw fuel and see brown smoke billowing out the **** end. But....When the engine comes up to normal operating temp, the problem seems to go away. Please...someone have an answer for this problem. Thanx.
1987 T/A GTA 5.7L, Bored .020 and ported for .202 valves, edelbrock headers, flowmaster exhaust, JET STAGE II chip, Comp CAM, Adjustable fuel pressure, Airfoil, K&N filter, B&M stage 2 shift kit, and a home depot ram air(Hey it looks good)
Old Jan 13, 2001 | 07:55 PM
Z's r Best's Avatar
Car: '86 IROC, black and sharp
Engine: 305 tpi, bone stock
Axle/Gears: 3.42 pos w/rear db
no experience with fuel injection. I've seen both our 81Z and 83Z do something similar with the back upper carb. plates would not open up. The 81Z would get up to about 4000 rpm and just stop winding higher, while the 83Z would flutter, miss and outright die if you didn't let up on the pedal. The 83Z had a bad vacuum pot (holds plate shut till you hit the gas) and a broken spring on the shaft. The 81Z just had a tight spring. Sound like maybe you are getting too much air, too soon (before you get the gas).
Z's r Best
theshackle
Sep 17, 2020 08:26 AM
db057
Aug 22, 2015 08:17 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
