strange sound from under dash - no crank
Old Jan 13, 2001 | 02:27 PM
Klatt's Avatar
wow i havent posted a message on here in atleast 6 months - hehe anyways im back - im getting a strange sound from under the dash by all the fuses. NO crank.. brand new battery...if i take the vats fuse out i still get nothing but no sound anymore...PLEASE help. i NEEED the car tonight...thnx..
frank
Old Jan 13, 2001 | 03:00 PM
Klatt's Avatar
update: when i take the acc (int acc) fuse out it doesnt make the weird sound but still no start - there was an alarm on the car but its been dissabled - when trying to start the car you can here faint sounds from the engine. weird stuff. like some weird noises by the speed density **** at the front of the plenum and once and a while i hear something coming from the starter - but not all the time.
we tried puttin the car in gear and rockign it to see if the starter was stuck but ntohing there. the car actually wont even roll forward at all. it could be my parking break sticking cuz it has b4 but it WILL roll backwards...
Old Jan 13, 2001 | 09:42 PM
Klatt's Avatar
some suggestions by some friends: starter, starter selenoid. fuseable link by the starter.....
Old Jan 14, 2001 | 08:56 AM
Klatt's Avatar
anyone????
Old Jan 14, 2001 | 09:57 AM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Has it ever started since the VATS was removed??
Check all battery cable connections.
Check condition of battery.
If thats all good, can you just jump the batt + cable on the starter to the start teminal and get it to crank??
If you can jump the terminals and it cranks, check for key power down at the starter while someone holds the key in the start position.
This should narrow down a few posibilities.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
GO #3
[This message has been edited by Engineboy (edited January 14, 2001).]
someone972
Aug 30, 2015 12:52 AM
red90IROCls1
Aug 25, 2015 06:56 AM
overdriv
Aug 20, 2015 03:52 PM
Dialed_In
Aug 20, 2015 01:45 PM
