bearings
Old Jan 4, 2004 | 11:51 PM
pskel350's Avatar
bearings
tore my engine down tonight, it has 5,000 miles on the shortblock.
the main and rod bearings are chewed up pretty bad already. 3 of the cam bearings are shot too. i was driving home from detroit one night after racing, about a 3 hour drive, and i lost 3 psi of oil pressure. it had never done that on longer drives before. why would the bearings be junk after a few thousand miles?
are 3/4 groove bearings a good idea?
does anyone have a part number?
also is the crank being turned .020 a bad thing? how much will it weaken it?
i broke it the cam the proper way, changed oil right after cam break in. then again after 500 miles, 1500 miles, then right before i went racing when i lost the oil pressure. there was never any metal shavings of any kind in the oil until i drained it to pull the engine.
Old Jan 5, 2004 | 04:14 AM
ede's Avatar
ede
do you know the clearances? what is the thrust? oil delivery problem? grinding the crank -.020 isn't a bad thing and doesn't have any real impact on strength.
6speedIROC
16
Mar 15, 2023 08:33 PM
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
gord327
Oct 3, 2015 01:25 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
mfp189
Sep 27, 2015 09:25 AM
