question about gear drive timing set
Old Jan 14, 2001 | 08:41 PM
bsnoke's Avatar
I recently purchased a Pete Jackson timing set off of a 91 Camaro with a 350 TPI. I am going to put it on my 87 T-A with a 305. The problem I have run into is the cam gear locks against the cam plate bolts. The cam gear has a bronze bushing on one side of it and I am sure that it goes toward the cam. Any help would be greatly appriciated. Ben
'87 T-A 305 TPI
IN PEICES RIGHT NOW
Old Jan 14, 2001 | 08:57 PM
Guest
Guest
Posts: n/a
I'd need my instructions, but IIRC the gear set came with 2 bolts that had smaller heads for the cam plate.
Old Jan 15, 2001 | 02:32 PM
Dennis_91GTA's Avatar
You might want to call Summit or somebody else and make sure that the Pete Jackson part number is the same for the two different applications. The '91 TPI 350 uses a roller cam. I'm not sure if your '87 305 does.
I hope this helps.
Dennis
Frozer!!!
Jan 19, 2024 04:55 PM
specialized
Jun 18, 2022 09:26 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
camaro71633
Sep 1, 2015 10:24 AM
jharrison5
Aug 19, 2015 05:53 PM
