What causes a tapping valve?
Old Jan 6, 2004 | 11:13 PM
azvolfan's Avatar
Car: currently thirdgenless!!!
And how do you get rid of it???
Old Jan 7, 2004 | 12:16 AM
ChrisFormula355's Avatar
Car: Junk
Engine: Junk with nitrous
Transmission: Junk with gears
Where and how loud? If its a consistent tapping, a valve readjustment may be in order. This is normal after a new cam is installed and everything "seats" itself. I normally readjust my valves about a week after a new cam install. If it taps just as you start the engine then dies down, its a sign of low oil pressure, but nothing to be really freaked about, now if it taps REALLY constistently even after a valve readjustment, it could be a sign of a clogged lifter or pump with a lot of clearance. Tapping noises come from a lot of places, and many time, ESPECIALLY after a new header installation, it is actually coming from the headers (ie exhaust leak). Trust me a tapping valve sounds almost exactly like a loose header. Tighten up ALL the header bolts and see if the noise is still there. Wouldn't be suprised if that was it. I find that my headers loosen their bolts the first week after an install and after one or two re-tightens they are good for a long time.
Old Jan 7, 2004 | 02:00 AM
azvolfan's Avatar
It's pretty constant.
I will try tightening the header bolts. See if that does it. Thanks Chris.
Old Jan 7, 2004 | 08:31 AM
ede's Avatar
ede
usually valve noise is caused by anything but valve. try looking for exhaust leak, injector making noise, rocker out of adjustment
gta892000
Sep 16, 2015 12:37 AM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
Ragtop Man
Sep 12, 2015 12:23 AM
dimented24x7
Sep 6, 2015 03:51 PM
