Replacing HCV
Replacing HCV
Hey guys,
I'm having a heat problem where I only get warm air....so I'm going to be replacing the Heater Control Valve for 14.99 at autozone. Anything I should keep in mind while replacing it, or just disconnect old lines, and put them on new one?
Thanks!
Thanks!
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
if you let teh car cool and open the radiator cap to let the pressure off, less leaks out.
expect to get some coolent leakage, nothing major or worth draining the system for.
