'88 350, internal or external balanced?
Old Jan 15, 2001 | 02:34 PM
camaroguy99's Avatar
I am building a 350 for my '88 camaro and I am buying the balancer soon. I see they have internal and external versions, but which one is right for my application? I think I understand the differance but haven't really been able to find a possitive answer. Thnkas for your help.
Jim
Old Jan 15, 2001 | 03:10 PM
MRZ28HO's Avatar
Car: was: 1984 Camaro Z28
Engine: was: L69
Transmission: was: 700-R4
Depends on the year of the block (kinda) and crank. If it is a 400 (any year) it is externally, if you choose not to convert it to internal. If it is a one-piece it is an external, similar to a 400. All others are internal, unless you convert it over. Confused? Are you using OEM pieces? Is it a 1-piece? If yes to both it is externally balanced.
George P. Lara
1984 "L69" A4
1994 LT1 M6
Member:
SCCA, SCFB, SC3GFB
Old Jan 15, 2001 | 06:37 PM
jms's Avatar
jms
All factory small block Chevys, except the 400, are internally balanced.
jms
Old Jan 15, 2001 | 07:06 PM
ede's Avatar
ede
to expand a little on what's been said. if you have a SBC with a one piece rear main seal it is internally balanced. the fly wheel/flex plate has a weight on it to make up for the lose material from the fly wheel flange being gone from the one piece seal cranks. it wasn't a weight, but it acted as one so the weight on the fly wheel/flex plate.
ICON Motorsports
1st & 3rd
Old Jan 15, 2001 | 07:37 PM
does that mean that I have to get a harmonic balancer that is internaly or externally balanced. I am using a OEM crank and connecting rods with a one piece rear main seal. Also would it be possible to use the flywheel/flex plate from my 305 TBI? Thanks again for all your help.
[This message has been edited by camaroguy99 (edited January 15, 2001).]
Old Jan 16, 2001 | 12:11 PM
Slow Iroc's Avatar
You have an internally balanced rotating assembly....that's all that needed to be said, so get an internally balanced (or neutral balance) dampener.
C409
Sep 23, 2015 04:30 PM
gixxer92
Sep 1, 2015 04:32 PM
Eric-86sc
Aug 24, 2015 09:01 PM
InfinityShade
Aug 22, 2015 08:00 PM
theshackle
Aug 22, 2015 06:52 PM
