Removal of Charcoal canister
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
I know what you are all going to say, I should leave it in there, but this is one case where it is not a good idea. I have switched over to a DFI unit that replaces the stock computer and there is no provisions for it. Therefore it is inoperable. The electrical plug that goes to it controls a valve to open and close but now there is no signal so it will not work right? How do I make a venting system so the tank does not build up excessive presure? Anyone done this yet?
Steve
Steve
I say you might as well leave it on there so you don't have gas fumes pervading the engine compartment. On the other hand I went a month without one and had no problem. Whatever you do make sure the tank is vented in some way.
82 z28 350cid, vortec heads, comp 262h cam, Holley 600cfm carb, 2in twice pipes, MSD ignition, turbo 350 trans, 3.73 posi, manly b&m megashifter
