Are Roll Pins Reusable?
Old Jan 15, 2001 | 08:02 PM
ede's Avatar
ede
ok i know it's not the greatest question ever asked on here and this might not even be the place to ask. i took one out the other day and got to wondering about it and couldn't find anything in any of my books. after i thought about it i figure they should be replaced each time.
ICON Motorsports
1st & 3rd
Old Jan 15, 2001 | 08:28 PM
Vader's Avatar
Ed,
As long as the roll pin has spring tension and isn't visibly marred, go ahead and use it again. If there's any spring tension, it should resist falling right through the intended bore. Distributor gear?
Later,
Vader
"I cannot take this any more... Saying everything I've said before..."
Adobe Acrobat Reader 4.0
KaleCo Auto Parts
Old Jan 15, 2001 | 09:02 PM
ede's Avatar
ede
no it was an oil pump. i use melling m55 pumps and change the spring with a mr. gasket #26 high preasure spring. it can only fall out one way and i staked it in place so it wouldn't. just something i was thinking about. i worry too much.
ICON Motorsports
1st & 3rd
Old Jan 15, 2001 | 10:08 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I've changed out a certain number of that exact roll pin, in that very application always with success. Roll pins are real generic, I think that one is 5/32 x 1/2 or some such, but I've never bothered, and never had one fall out on me.
Go for it.
Old Jan 15, 2001 | 10:11 PM
Vader's Avatar
Damn, Ed. You should have plenty of oil in the infamous "Almost V-8". That's usually enough flow and pressure for a lot more gallery and cylinder than you're working on. At least you won't starve it...
Later,
Vader
KaleCo Auto Parts
Old Jan 16, 2001 | 04:30 PM
ede's Avatar
ede
well vader i did the same thing to my almost 350, but this is for a 355 i'm doing. i don't know why i would start to worry about this, i must of changed a boat load of springs reuseing the roll pin with no problems. like i said i worry too much.
ICON Motorsports
1st & 3rd
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
shanelique22
Oct 3, 2015 07:23 PM
FormulaEngland
Sep 30, 2015 01:50 PM
