Teflon Tape on Intake Bolts
Old Jan 11, 2004 | 06:19 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Would it work? I've used it on my screw in studs with good results. Just wondering.
Old Jan 11, 2004 | 06:27 PM
Vader's Avatar
Tape might be better than nothing, but it is not ideal. Tape and most pipe compounds are made to lubricate the thread and slightly seal tapered pipe joints. It isn't made to seal larger gaps of straight threads.
The better solution would be to use an anerobic thread sealant, like Loctite/Permatex PST. It contains teflon, but also is a sealant that will control larger gaps in straight threads under excessive pressure and temperature variations.
Old Jan 12, 2004 | 04:45 AM
ede's Avatar
ede
i agree with mr. vader, tape is better than nothing but liquid tefelon or loctite would be a lot better
Old Jan 12, 2004 | 07:15 PM
JRoy91RS's Avatar
Car: 91 RS Convertible
Engine: 355
Axle/Gears: 2.73 peg leg
Yeah, why risk teflon tape? Besides, I can never get the residue entirely off after I torque down a fitting and it always looks kinda crappy. Thread sealant doesn't cost that much, either.
Old Jan 12, 2004 | 07:20 PM
Erin91RS's Avatar
Car: 91 RS
Transmission: 700-R4
Whats the differance between the tape and sealant?
Old Jan 12, 2004 | 07:22 PM
JRoy91RS's Avatar
Engine: 355
Well, for starters, the tape is solid, and is kinda a pain to apply correctly. The sealant is a liquid that contains teflon and a sealing agent when it dries. All it takes is a drop on the end of the threads and you're ready to seal it up.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
lt1z350
Sep 14, 2015 10:07 AM
TreDeClaw
Aug 14, 2015 06:58 PM
