how much power do you think my set-up might make?
Old Jan 11, 2004 | 09:48 PM
Rogue86's Avatar
Car: 94 Camaro
Engine: 380 sbc
Transmission: th400
Axle/Gears: 9" 4.11
Alright, I'm just getting curious, and thought I'd ask you guys what you thought I might be looking at for power (hp and torque) out of this engine set-up:
newly rebuilt 350 .060 over
stock dished pistons, rods w/ arp bolts, and stock polished crank
305 #416 heads with crane springs
summit 1103 cam 214/224 @.50 .442/.465 112lsa
edelbrock performer intake
gm HEI ignition
long tube headers with 2.5"(should I go 3"?) dual pipes no mufflers
holley 1850 600 cfm carb
Thanks for any opinions ya can give me
Old Jan 12, 2004 | 10:22 AM
GASGZLR's Avatar
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
I say 320 HP at 5500 and about 375 Tq at 3800. Just my opinion
Old Jan 12, 2004 | 12:36 PM
SweetS10v8's Avatar
Car: '89 Formula 350 & '86 Z28
Engine: L98 & 355ci
Transmission: 700r4 in both
Desktop Dyno says 260hp @ 4500 and 350lb/ft at 3000rpm
Here are my opinions:
This could be a nice stock street cruiser, but not a drag motor. With that in mind I would put a mufflers on it. It will be obnoxious to drive on the street and it will most likely get you a ticket too. With this mild of a motor the HP a muffler robs will not be noticable. Turbo mufflers are $20
I would buy some .015 head gaskets to raise your compression a bit more.
3" is overkill, 2.5" would be a little too much, and 2 1/4" would give you the most clearance and you wouldnt lose any real HP at this level. Assuming your doing duals off of the longtubes....
I would choose a smaller cam too, 224 is a lot of duration for a stock motor! The motor isnt going to be seeing high rpms so a smaller cam will offer better torque through your powerband(idle-4500). Torque is what you want. That seat of the pants feel when you mash the pedal. Something in the 208-216 range
Also another cheap way to get that pseudo HP is by changing gears. Dont know what you have now, but swapping form a 2.73 to a 3.42 "feels" like you gained 50hp!! But your th350 limits you there, eventually you should find a 700r4 and install it. then sell the th350 and buy a set of gears.
Edit: keep the cam you have choosen if you want a rougher idle, you just have to sacrafice some usable torque for it
Old Jan 12, 2004 | 12:45 PM
Ray87Z's Avatar
Car: 94 Z28
Engine: LT1 w/ headers, catback, CAI, tune
Axle/Gears: 3.23s
I'd give it 275hp max, probably less... Crappy heads without a whole lot of porting work, and then a crappy combustion chamber design regardless.... I'd put a muffler on it too, too *******...
Old Jan 12, 2004 | 01:25 PM
Rogue86's Avatar
Car: 94 Camaro
Engine: 380 sbc
Transmission: th400
Axle/Gears: 9" 4.11
This car will be a track only car. Even though it won't be the best drag motor it is just for me to compete in bracket high school class at the local 1/8 mile against cars like stock cavaliers ect.
All creature comforts from the car are gone in the name of weight reduction. I may have to put mufflers on to race in the high school class, depends on how picky they get.
Most likely it will be trailered so I don't have to pay the insurance. I already get raped on the 95's v6 insurance.
Old Jan 12, 2004 | 02:32 PM
SweetS10v8's Avatar
Engine: L98 & 355ci
Then ditch those dished pistons and buy some cheap flattops. Cast piston can be had for $16.
Old Jan 12, 2004 | 03:42 PM
Rogue86's Avatar
Car: 94 Camaro
Engine: 380 sbc
Transmission: th400
Axle/Gears: 9" 4.11
The motor is already done, too late for that.
jaridjohn
Jul 8, 2024 03:49 PM
jhawkeye
May 25, 2022 06:33 PM
theshackle
Sep 17, 2020 08:26 AM
86White_T/A305
Aug 17, 2015 12:16 AM
novaderrik
Aug 10, 2015 12:44 PM
